[postgis-tickets] [PostGIS] #2269: Unreasonable memory usage when analyzing table with geometry column with many toasted datums
PostGIS trac at osgeo.org
Tue Apr 9 20:31:38 PDT 2013
many toasted datums
  Reporter:  pgeoghegan  |       Owner:  strk
      Type:  defect      |      Status:  closed
  Priority:  blocker     |   Milestone:  PostGIS 2.0.4
 Component:  postgis     |     Version:  2.0.x
Resolution:  fixed       |    Keywords:  toast,leak
Changes (by robe):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Works fine on my pc 9.2w64 (haven't tried on 8.4 32-bit).
 I think winnie's issue is because I copied the wrong version of libxml
 during PostgresQL upgrade install so postgis dll doesn't even load since
 the 9.0 seems ot be fine which I didn't get around to ugprading.  I'll
 rerun after I fixed this, but seems unrelated.
 I'll close and reopen if I still see problems.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2269#comment:15>
