[postgis-tickets] [PostGIS] #2270: Set NOT NULL constraint on the geometry column with '-N skip'
PostGIS trac at osgeo.org
Wed Apr 10 22:24:10 PDT 2013
  Reporter:  francoisb      |       Owner:  mcayland
      Type:  enhancement    |      Status:  closed
  Priority:  medium         |   Milestone:
 Component:  loader/dumper  |     Version:  2.0.x
Resolution:  wontfix        |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 I don't agree.  Often times I load in data with plan to add data later.  I
 don't necessarily plan to load data with not null geometries since I
 sometimes add the attribute data first and then update from another table
 with a geometry.  I see this as missplaced in -N skip (confusing doing too
 much when not asked for) and just as easy for a user to do themselves.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2270#comment:1>
