[postgis-tickets] [PostGIS] #2271: make -j N not working if postgis_raster enabled
PostGIS trac at osgeo.org
Thu Apr 11 12:14:29 PDT 2013
 Reporter:  iacovellas  |       Owner:  strk
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:
Component:  postgis     |     Version:  2.0.x
 Keywords:              |
 Compiling PostGIS with -j option fails if postgis_raster is enabled.
 I have tested on Linux Mint 14x86 with PostGIS 2.0.3
 when compiling with
 $ ./configure
 $ make -j 4 all
 it fails with following error:
 gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
 statement -Wendif-labels -Wmissing-format-attribute -Wformat-security
 -fno-strict-aliasing -fwrapv -fexcess-precision=standard -fpic -shared -o
 rtpostgis-2.0.so rt_pg.o -L/usr/local/pgsql/lib -L/usr/lib  -Wl,--as-
 needed -Wl,-rpath,'/usr/local/pgsql/lib',--enable-new-dtags
 ../rt_core/librtcore.a ../../liblwgeom/.libs/liblwgeom.a
 ../../libpgcommon/libpgcommon.a -L/usr/local/lib -lgdal  -L/usr/local/lib
 -lgeos_c -lproj -ljson -L/usr/lib -lxml2
 gcc: error: ../rt_core/librtcore.a: No such file or directory
 make[2]: *** [rtpostgis-2.0.so] Error 1
 make[2]: *** Waiting for unfinished jobs....
 make[2]: Leaving directory
 `/home/stefano/sources/postgis-2.0.3/raster/rt_pg'
 make[1]: *** [pglib] Error 2
 make[1]: *** Waiting for unfinished jobs....
 ar rs librtcore.a rt_api.o
 ar: creating librtcore.a
 make[3]: Leaving directory
 `/home/stefano/sources/postgis-2.0.3/raster/rt_core'
 /bin/bash ../../libtool --mode=link gcc -g -O2  -fPIC -DPIC  -Wall
 -Wmissing-prototypes -I../rt_core -I../../liblwgeom
 -I/usr/local/pgsql/include -I/usr/local/include -I/usr/local/include
 raster2pgsql.o ../rt_core/librtcore.a ../rt_core/librtcore.a
 ../../liblwgeom/liblwgeom.la -L/usr/local/pgsql/lib -lpq -L/usr/local/lib
 -lgdal -L/usr/local/lib -lgeos_c  -lc -lm -o raster2pgsql
 libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
 -I../rt_core -I../../liblwgeom -I/usr/local/pgsql/include
 -I/usr/local/include -I/usr/local/include raster2pgsql.o -o
 .libs/raster2pgsql  ../rt_core/librtcore.a
 ../../liblwgeom/.libs/liblwgeom.so -L/usr/local/pgsql/lib -lpq
 -L/usr/local/lib /usr/local/lib/libgdal.so /usr/local/lib/libgeos_c.so -lc
 -lm
 `/home/stefano/sources/postgis-2.0.3/raster/loader'
 make[1]: Leaving directory `/home/stefano/sources/postgis-2.0.3/raster'
 make: *** [all] Error 1
 when compiling with
 $ ./configure --without_raster
 $ make -j 4 all
 There is no error
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2271>
