[postgis-tickets] [PostGIS] #2264: Fix postgis_restore.pl to upgrade from PostGIS installed in a dedicated schema
PostGIS trac at osgeo.org
Fri Apr 12 07:58:37 PDT 2013
schema
 Reporter:  frost242               |       Owner:  strk
     Type:  patch                  |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.4
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:                         |
Comment(by frost242):
 Comments adressed in the attached patch.
 I used the same construct as for -v, that means the options must be passed
 in a defined order: -v always before -s. I hope it's OK this way.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2264#comment:7>
