[postgis-tickets] [PostGIS] #2264: Fix postgis_restore.pl to upgrade from PostGIS installed in a dedicated schema
PostGIS trac at osgeo.org
Fri Apr 12 09:10:57 PDT 2013
schema
  Reporter:  frost242               |       Owner:  strk
      Type:  patch                  |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.0.4
 Component:  build/upgrade/install  |     Version:  2.0.x
Resolution:  fixed                  |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Better, I improved the option parsing so you can specify in arbitrary
 order as long as it is before the dump filename. It's in trunk @ r11285
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2264#comment:8>
