[postgis-tickets] [PostGIS] #2264: Fix postgis_restore.pl to upgrade from PostGIS installed in a dedicated schema
PostGIS trac at osgeo.org
Fri Apr 12 09:19:57 PDT 2013
schema
  Reporter:  frost242               |       Owner:  strk
      Type:  patch                  |      Status:  reopened
  Priority:  medium                 |   Milestone:  PostGIS 2.1.0
 Component:  build/upgrade/install  |     Version:  2.0.x
Resolution:                         |    Keywords:
Changes (by strk):
  * status:  closed => reopened
  * resolution:  fixed =>
  * milestone:  PostGIS 2.0.4 => PostGIS 2.1.0
Comment:
 Actually I'm reopening because the code still lacks adding -s semantic to
 Usage output (see bottom line of the output, it tells you about -v but not
 about -s).
 A note in the manual may also be nice to have.
 Actually I'm also unclear myself about what the switch does. It looks like
 restoring into a database in which postgis is installed in a custom
 schema, is that correct ?
 But how does it deal with a _dump_ having postgis in a custom schema ?
 Is it still able to drop that one ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2264#comment:9>
