[postgis-tickets] [PostGIS] #2264: Fix postgis_restore.pl to upgrade from PostGIS installed in a dedicated schema
PostGIS trac at osgeo.org
Mon Apr 15 01:04:59 PDT 2013
schema
  Reporter:  frost242               |       Owner:  strk
      Type:  patch                  |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.1.0
 Component:  build/upgrade/install  |     Version:  2.0.x
Resolution:  fixed                  |    Keywords:
Changes (by strk):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 r11296 adds to usage string. Will not touch the postgis manual as this new
 switch seems partial to me (some of the signatures to be skipped from the
 dump have "public" schema name hard-coded, thus restoring a dump in which
 postgis is in a separate schema would fail to skip those functions, even
 with the -s switch).
 Anyway, considering this complete.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2264#comment:10>
