[postgis-tickets] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Fri Apr 12 12:32:33 PDT 2013
  Reporter:  robe     |       Owner:  robe
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.4
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:  mingw64, history
Comment(by jesseeichar):
 Just as an additional quick test.  I think it is related.  Could you try
 the following out on you system:
 select ST_AsText(ST_GeomFromText('POLYGON ((8.176 47.222, 8.174 47.227,
 8.185 47.235, 8.183 47.24, 8.179 47.241, 8.173 47.236, 8.172 47.228, 8.161
 47.232, 8.156 47.239, 8.18 47.246, 8.207 47.25, 8.208 47.247, 8.202
 47.226, 8.176 47.222))'))
 On a 64 bit windows 8 install with
   "PostgreSQL 9.2.3, compiled by Visual C++ build 1600, 32-bit"
   "POSTGIS="2.0.3 r11132" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6
 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" TOPOLOGY RASTER"
 I get the obviously broken result:
   "POLYGON((8.176 47.222,8.174 47.227,8.185 47.235,8.183 47.24,8.179
 47.241,8.173 47.236,8.172 47.228,8.161 47.232,8.156 47.239, , 47.25,8.208
 47.247,8.202 47.226,8.176 47.222))"
 (Notice the 8.156 47.239, , 47.25)
 Thanks,
 Jesse
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:57>
