[postgis-tickets] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Fri Apr 12 14:31:17 PDT 2013
  Reporter:  robe     |       Owner:  robe
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.4
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:  mingw64, history
Comment(by robe):
 Jesse,
 I get this
 on my windows 7 9.2 32-bit -
 PostgreSQL 9.2.1, compiled by Visual C++ build 1600, 32-bit POSTGIS="2.0.3
 r11132" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0, 6 March 2012"
 GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8" LIBJSON="UNKNOWN"
 RASTER
 POLYGON((8.176 47.222,8.174 47.227,8.185 47.235,8.183 47.24,8.179
 47.241,8.173 47.236,8.172 47.228,8.161 47.232,8.156 47.239,8.18
 47.246,8.207 47.25,8.208 47.247,8.202 47.226,8.176 47.222))
 So looks fine.  But this is running on my 2.1.0 build.
 It sounds like you got my broken build.  If you installed with zip files
 that didn't have a -2 or an installer that didn't have a -2, then you got
 a bad build.  I was hoping I swapped out before too many people were
 affected.
 Reinstall using one of these and you should be fine:
 http://download.osgeo.org/postgis/windows/pg92/
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:58>
