[postgis-tickets] [PostGIS] #2260: Benchmarking speed between built-in tiger normalizer and pagc_address_parser
PostGIS trac at osgeo.org
Sat Apr 20 10:51:02 PDT 2013
pagc_address_parser
 Reporter:  robe                 |       Owner:  robe
     Type:  task                 |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
Comment(by robe):
 Yah I should probably research on tools for debugging in windows. I'm
 guessing the reason why removing SP_finish prevents it from crashing is
 that SP_finish is trying to clean memory it thinks is under pg memory
 management and over steps the address space thus triggering a "No No not
 yours" error in.  I tried playing with those SP_pop, SP_push functions but
 got no where with those.
 I guess worst comes to worse I could use the old library version before
 you merged everything into one folder. That one works fine.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2260#comment:14>
