[postgis-tickets] [PostGIS] #2279: Can't upgrade PostGIS from 2.0
PostGIS trac at osgeo.org
Tue Apr 23 22:26:23 PDT 2013
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Description changed by robe:
Old description:
> This I suspect is just an extension issue and I have to put in extra
> logic for this.  I'll double check but I did my usual micro-micro upgrade
>  Upgrading from 2.1.0 SVN r11142 to r11306
> with
> ALTER EXTENSION postgis UPDATE TO "2.1.0SVNnext";
> and got this
> ERROR:  cannot drop function
> geometry_gist_sel_2d(internal,oid,internal,integer) because other objects
> depend on it
New description:
 UPDATE: on closer inspection this makes it IMPOSSIBLE to do a soft upgrade
 from 2.0 to 2.1 with or without extensions.
 ----------- OLD NOTE -----
 This I suspect is just an extension issue and I have to put in extra logic
 with
 and got this
 depend on it
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2279#comment:6>
