[postgis-tickets] [PostGIS] #2279: Can't upgrade PostGIS from 2.0
trac at osgeo.org
Sun Apr 28 12:51:10 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
I looked into this problem more. I can salvage your dropping of
DROP FUNCTION IF EXISTS geometry_gist_sel_2d (internal, oid, internal,
int4);
DROP FUNCTION IF EXISTS geometry_gist_joinsel_2d(internal, oid, internal,
smallint);
simply by putting in do logic to rename the original and then updating
with the new C function. Unfortunately with your geography ones and 3D
&&&, I can't do that since both share the same set of functions so I can
only rename one.
So which would you rather have:
different names pointing to same C functions
or
partial duplicates (e.g. salvage geometry2d and live with
geography/geometry 3d having slightly different named casts in 2 ugrade
or
back to duplicate naming for everything.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2279#comment:7>
