[postgis-tickets] [PostGIS] #2284: standardize_address doesn't accept schema qualified table names
PostGIS trac at osgeo.org
Thu Apr 25 02:51:50 PDT 2013
 Reporter:  robe                 |       Owner:  robe
     Type:  defect               |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
Comment(by robe):
 Also need to support this syntax:
 select (std).* from (
     select standardize_address('"public"."lex"', '"public"."gaz"',
 '"public"."rules"', micro, macro) as std
       from addresses) as foo;
 Since if people are anal enough or crazy enought to use mixed case in
 their tables they'll want/need to quote their tables and their schemas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2284#comment:1>
