[postgis-tickets] [PostGIS] #2284: standardize_address doesn't accept schema qualified table names
PostGIS trac at osgeo.org
Thu Apr 25 17:22:45 PDT 2013
 Reporter:  robe                 |       Owner:  robe
     Type:  defect               |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:                       |
Comment(by woodbri):
 The current code supports the following syntax:
 select (std).* from (
     select standardize_address('public.lex', 'public.gaz', 'public.rules',
 micro, macro) as std
       from addresses) as foo;
 I can probably allow '"' chars to be ok also.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2284#comment:2>
