[postgis-tickets] [PostGIS] #2291: &&& can't be upgraded from 2.0 to 2.1
PostGIS trac at osgeo.org
Sun Apr 28 14:50:12 PDT 2013
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 As noted in ticket #2279 since the definition of &&& was changed from
 2.0
 CREATE OPERATOR &&&(
   PROCEDURE = geometry_overlaps_nd,
   LEFTARG = geometry,
   RIGHTARG = geometry,
   COMMUTATOR = &&&,
   RESTRICT = contsel,
   JOIN = contjoinsel);
 to 2.1
   LEFTARG = geometry,
   COMMUTATOR = &&&,
   RESTRICT = gserialized_gist_sel_nd,
   JOIN = gserialized_gist_joinsel_nd);
 I presume this means 3D geometry users using &&& will not be able to
 benefit from the fruits of pramsey's labor.
 The problem is you can't drop the operator without dropping the
 gist_geometry_ops_nd class
 and if you drop the opclass you have to drop the 3D indexes.
 The good news is not that many people are using that index and I suspect
 even know about it so probably doesn't affect that many people.
 Options that come to mind:
 1) drop if we see in use and also try to drop the operator class and
 rebuild.  users who have indexes will get an error during upgrade, but new
 users who have not started using this feature will get a clean upgrade
 2) Do nothing except document the issue, tell people they need to dump
 /restore if they are or plan to use 3D and let them fend for themselves
 3) Provide a script that drops and rebuilds the indexes (would have to
 itemize)
 2 is the easiest for us, meanest for users, but at least we warned if they
 new where to look in the docs.
 3) sounds complicated
  1) is a good balance that is not too hard and yet is nice to future
 users.
 Given we don't have too many people using 3D yet, I'm leaning toward 1.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2291>
