[postgis-tickets] [PostGIS] #2292: GDAL Requirement
PostGIS trac at osgeo.org
Mon Apr 29 15:57:56 PDT 2013
 Reporter:  newbie216      |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:
Component:  documentation  |     Version:  2.0.x
 Keywords:                 |
 In the installation documentation under the section '2.2 Requirements',
 GDAL is listed as a required package for building or using PostGIS. I was
 able to install PostGIS without GDAL. Another developer here is using
 PostGIS and running tests against it without installing GDAL. I don't know
 if this was a packaging issue or the document should list GDAL as an
 optional package. I read the description for GDAL as being required, but
 others read it as only being required for raster support. Need
 clarification.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2292>
