[postgis-tickets] [PostGIS] #2203: [raster]: Can't read out_db jpg in some cases
PostGIS trac at osgeo.org
Sat Feb 16 07:05:30 PST 2013
  Reporter:  robe    |       Owner:  dustymugs
      Type:  defect  |      Status:  reopened
  Priority:  medium  |   Milestone:  PostGIS 2.1.0
 Component:  raster  |     Version:  trunk
Resolution:          |    Keywords:  history
Comment(by robe):
 Okay I just reloaded -- here is what I found:
 SELECT ST_SummaryStats(rast) FROM armory_outdb limit 1;
 (27000000,2665449805,98.7203631481482,81.4870806656832,0,255)
 Run the above a second time KABOOM server instance crashes and comes
 toppling down :)
 Resize still doesn't work and to rule out the folder, I added another
 image to it and registered that file as an out db and that one works fine.
 If it helps when I run resize I get this extra info in the database logs:
 ERROR 1: libjpeg: Failed to create temporary file
 ERROR 1: C:/pics/back.jpg, band 2: IReadBlock failed at X offset 0, Y
 offset 0
 ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
 I'm going to try next on my mingw instance to see if its an EDB windows
 instance issue.  haven't tried on my 32-bit instance yet either.  I have
 5GB of disk space left so I assume that is not the issue.  I think I'm
 running with default postgres.conf for my development instance.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2203#comment:9>
