[postgis-tickets] [PostGIS] #2203: [raster]: Can't read out_db jpg in some cases
PostGIS trac at osgeo.org
Mon Feb 18 15:46:43 PST 2013
  Reporter:  robe    |       Owner:  dustymugs
      Type:  defect  |      Status:  assigned
  Priority:  medium  |   Milestone:  PostGIS 2.1.0
 Component:  raster  |     Version:  trunk
Resolution:          |    Keywords:  history
Comment(by dustymugs):
 Can you also set the following environment variable, restart PostgreSQL
 and then run ST_SummaryStats()?
 CPL_DEBUG=ON
 GDAL debug output will probably end up in PostgreSQL's log.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2203#comment:42>
