[postgis-tickets] [PostGIS] #2203: [raster]: Can't read out_db jpg in some cases
PostGIS trac at osgeo.org
Tue Feb 19 04:02:31 PST 2013
  Reporter:  robe    |       Owner:  dustymugs
      Type:  defect  |      Status:  assigned
  Priority:  medium  |   Milestone:  PostGIS 2.1.0
 Component:  raster  |     Version:  trunk
Resolution:          |    Keywords:  history
Comment(by robe):
 I see this in the logs when I have that ON
 GDAL: GDALOpen(C:/pics/back.jpg, this=000000000499FAD0) succeeds as JPEG.
 VRT: VRTSourcedRasterBand::SetMetadataItem(STATISTICS_MINIMUM,0,)
 VRT: VRTSourcedRasterBand::SetMetadataItem(STATISTICS_MAXIMUM,255,)
 VRT:
 VRTSourcedRasterBand::SetMetadataItem(STATISTICS_MEAN,98.720363148148,)
 VRT:
 VRTSourcedRasterBand::SetMetadataItem(STATISTICS_STDDEV,81.487080665688,)
 ERROR 1: libjpeg: Failed to create temporary file
 ERROR 1: C:/pics/back.jpg, band 1: IReadBlock failed at X offset 0, Y
 offset 0
 ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
 ERROR:  rt_raster_from_gdal_dataset: Unable to get data from GDAL raster
 CONTEXT:  SQL function "st_summarystats" statement 1
 STATEMENT:  SELECT ST_SummaryStats(rast) from armory_outdb
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2203#comment:43>
