[postgis-tickets] [PostGIS] #2209: [raster]: String of 388800145 bytes is too long for encoding conversion
PostGIS trac at osgeo.org
Thu Feb 21 08:42:39 PST 2013
  Reporter:  robe           |       Owner:  robe
      Type:  defect         |      Status:  closed
  Priority:  medium         |   Milestone:  PostGIS 2.1.0
 Component:  documentation  |     Version:  trunk
Resolution:  fixed          |    Keywords:
Comment(by robe):
 I made some typos on my tags, but finally got it right -- so you can see
 if in
 http://postgis.net/docs/manual-
 dev/RT_FAQ.html#qa_raster_fails_encoding_conversion
 If looks okay to you I can make the same change to 2.0.  I'll assume you
 are okay with it unless I hear otherwise.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2209#comment:6>
