[postgis-tickets] [PostGIS] #2209: [raster]: String of 388800145 bytes is too long for encoding conversion
PostGIS trac at osgeo.org
Thu Feb 21 08:48:49 PST 2013
  Reporter:  robe           |       Owner:  robe
      Type:  defect         |      Status:  closed
  Priority:  medium         |   Milestone:  PostGIS 2.1.0
 Component:  documentation  |     Version:  trunk
Resolution:  fixed          |    Keywords:
Comment(by dustymugs):
 The only suggestion I have is that instead of "String of 388800145 bytes",
 you should just substitute the number with N... "String of N bytes".  This
 is because the numerical value is dependent on the length of the string to
 be converted.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2209#comment:7>
