[postgis-tickets] [PostGIS] #2215: [raster] Different constraints set for in-db and out-db
PostGIS trac at osgeo.org
Tue Feb 26 07:52:04 PST 2013
 Reporter:  mloskot      |       Owner:  dustymugs
     Type:  defect       |      Status:  new
 Priority:  medium       |   Milestone:
Component:  raster       |     Version:  trunk
 Keywords:  constraints  |
 (This ticket follows the postgis-devel thread on
 [http://lists.osgeo.org/pipermail/postgis-devel/2013-February/023234.html
 Testing out-db and regular blocking].)
 I'm running a simple test:
  * single GeoTIFF, 512x256 pixels, RGB
  * loaded as single image, no cutting into tiles
 I noticed, these two commands set different regular_blocking constraint:
 raster2pgsql     -C -r  -> TRUE
 raster2pgsql -R -C -r  -> FALSE
 I attached screenshot with all the values in raster_columns view
 presented.
 The PostgreSQL server runs as postgres user and has access to the
 world.tif file
 postgres:~$ ps -ef|grep '9.1/bin/postgres'
 postgres  1012     1  0 10:09 ?        00:00:00
 /usr/lib/postgresql/9.1/bin/postgres -D /var/lib/postgresql/9.1/main
 -c config_file=/etc/postgresql/9.1/main/postgresql.conf
 postgres:~$ ls -l  /home/mloskot/data/geotiff/world.tif
 -rw-r--r-- 1 mloskot mloskot 411822 Apr 14  2008
 postgres:~$ gdalinfo  /home/mloskot/data/geotiff/world.tif
 Driver: GTiff/GeoTIFF
 Files: /home/mloskot/data/geotiff/world.tif
        /home/mloskot/data/geotiff/world.tif.aux.xml
 Size is 512, 256
 Here is Bash script that generates test tables:
 #!/bin/bash
 # Test loading single image/tile as in-db and out-db
 # using three raster2pgsql modes: default flags, -C and -C -r
 # Build: PostGIS Raster (trunk at r11115), GEOS (trunk), GDAL (trunk)
 U=postgres
 O=mloskot
 D=rasters2
 # world.tif, 512x256, RGB, GeoTIFF
 R=/home/mloskot/data/geotiff/world.tif
 dropdb -U ${U} ${D}
 createdb -U ${U} -O ${O} ${D}
 [[ $? -ne 0 ]] && exit 1
 psql -U ${U} -d ${D} -c 'CREATE EXTENSION postgis'
 echo "-R
 raster2pgsql -R ${R} out_R > out_R.sql
 echo "-R -C
 raster2pgsql -R -C ${R} out_R_C > out_R_C.sql
 echo "-R -C -r
 raster2pgsql -R -C -r ${R} out_R_C_r > out_R_C_r.sql
 echo
 raster2pgsql ${R} in > in.sql
 echo "-C
 raster2pgsql -C ${R} in_C > int_C.sql
 echo "-C -r
 raster2pgsql -C -r ${R} int_C_r > int_C_r.sql
 echo
 echo "DONE: $?"
 for f in *.sql
 do
     psql -d ${D} -f ${f}
 done
 Bborie's posted [http://lists.osgeo.org/pipermail/postgis-
 devel/2013-February/023237.html first diagnosis]:
   ''there's an error creating the implicit exclusion index for the
 enforce_spatially_unique_rast constraint''
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2215>
