[postgis-tickets] [PostGIS] #2215: [raster] Use of exclusion constraint on multiple tables fails due to name of implicit index (was: [raster] Different constraints set for in-db and out-db)
PostGIS trac at osgeo.org
Tue Feb 26 09:42:28 PST 2013
of implicit index
  Reporter:  mloskot  |       Owner:  dustymugs
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.1.0
 Component:  raster   |     Version:  trunk
Resolution:  fixed    |    Keywords:  constraints, history
Changes (by dustymugs):
  * keywords:  constraints => constraints, history
  * status:  new => closed
  * resolution:  => fixed
  * milestone:  => PostGIS 2.1.0
Comment:
 Fixed in r11117.
 A simplified test case.
 CREATE TABLE foo AS
         SELECT
                 id
         FROM generate_series(1, 5) t(id);
 CREATE TABLE bar AS
         SELECT
                 id
 ALTER TABLE foo
         ADD CONSTRAINT enforce_unique_id EXCLUDE (id WITH =);
 ALTER TABLE bar
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2215#comment:1>
