[postgis-tickets] [PostGIS] #2374: cunit failures not flagged as failures
PostGIS trac at osgeo.org
Tue Jul 2 20:45:28 PDT 2013
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.2.0
Component:  buildbots  |     Version:  2.0.x
 Keywords:             |
 I just noticed this issue when setting up pointcloud build job that it was
 registering success even when cunit failures.  I dont' think this has been
 an issue in postgis since the perl tests give standard errors that jenkins
 picks up.
 I have a similar issue with pgrouting (I think also with how ctest from
 cmake outputs errors).
 Seems I have to do some complicated stuff to get jenkins to correctly flag
 these errors.
 http://stackoverflow.com/questions/10623800/cunit-failures-in-hudson-show-
 success
 As noted in above thread.  I hope there is an easier solution.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2374>
