[postgis-tickets] [PostGIS] #2374: cunit failures not flagged as failures
PostGIS trac at osgeo.org
Thu Jul 4 00:03:46 PDT 2013
  Reporter:  robe       |       Owner:  robe
      Type:  defect     |      Status:  closed
  Priority:  medium     |   Milestone:  PostGIS 2.2.0
 Component:  buildbots  |     Version:  2.0.x
Resolution:  invalid    |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 nevermind.  Cunit is fine.  it was make install causing the issue because
 I didn't force an exit on cunit failure.
 Just cmake tests I have issue with.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2374#comment:1>
