[postgis-tickets] [PostGIS] #2307: ST_MakeValid outputs invalid geometries
PostGIS trac at osgeo.org
Tue Jul 2 23:53:32 PDT 2013
  Reporter:  dmiranda  |       Owner:  pramsey
      Type:  defect    |      Status:  reopened
  Priority:  high      |   Milestone:  PostGIS 2.0.4
 Component:  postgis   |     Version:  2.0.x
Resolution:            |    Keywords:  st_makevalid
Changes (by strk):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Thanks, but test in r11620 is only at the PostgreSQL level, where memory
 management is performed with leak-free palloc system. My concern is at
 liblwgeom level, where NOT freeing might result in a leak, doesn't it ?
 As far as I can tell, the lwgeom_as_multi function always creates new
 memory, not wrapping the input, check out
 http://trac.osgeo.org/postgis/browser/tags/2.1.0beta3/liblwgeom/lwgeom.c#L284
 Maybe there's a bug in lwgeom_clone, used when the input to
 lwgeom_as_multi is a collection ?
 Please add the test to cunit/cu_clean.c so we can more easily put under
 valgrind.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2307#comment:6>
