[postgis-tickets] [PostGIS] #2307: ST_MakeValid outputs invalid geometries
PostGIS trac at osgeo.org
Wed Jul 3 07:42:02 PDT 2013
  Reporter:  dmiranda  |       Owner:  pramsey
      Type:  defect    |      Status:  reopened
  Priority:  high      |   Milestone:  PostGIS 2.0.4
 Component:  postgis   |     Version:  2.0.x
Resolution:            |    Keywords:  st_makevalid
Comment(by dmiranda):
 Hello, just to let you know, I have briefly tested the solution in trunk
 and the output seems ok.
 I do not have enough knowledge about the inner workings of pgsql or
 postgis to comment on the potential memory leak.
 Suppose it does leak memory, is there any test I could run to force the
 leak to appear?
 Please let me know if I can be of any help.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2307#comment:7>
