[postgis-tickets] [PostGIS] #2385: ST_MakeLine causing out of memory error
PostGIS trac at osgeo.org
Thu Jul 18 06:04:56 PDT 2013
  Reporter:  ris         |       Owner:  pramsey
      Type:  defect      |      Status:  closed
  Priority:  medium      |   Milestone:
 Component:  postgis     |     Version:  2.0.x
Resolution:  worksforme  |    Keywords:  ST_MakeLine memory aggregate
Changes (by robe):
  * status:  new => closed
  * resolution:  => worksforme
Comment:
 Okay my windows 64-bit 2008 R2 PostGIS 2.1 production instance finished
 and IT DID NOT FAIL.
 POSTGIS="2.1.0rc2 r11663" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0,
 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" TOPOLOGY RASTER PostgreSQL 9.2.4, compiled by Visual C++
 build 1600, 64-bit
 So given this, I'm dismissing this as a non-issue and propose you make
 sure you are running the latest PostgreSQL micros.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2385#comment:2>
