[postgis-tickets] [PostGIS] #2385: ST_MakeLine causing out of memory error
PostGIS trac at osgeo.org
Thu Jul 18 06:19:22 PDT 2013
  Reporter:  ris      |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:
 Component:  postgis  |     Version:  2.0.x
Resolution:           |    Keywords:  ST_MakeLine memory aggregate
Changes (by ris):
  * status:  closed => reopened
  * resolution:  worksforme =>
Comment:
 I respectfully disagree.
 Whether your machine actually runs out of memory or not, this is still a
 memory leak of some sort. One million 10-point linestrings is not ''that''
 big a deal, and shouldn't be using gigs and gigs of memory.
 Alternatively, I could re-submit the bug with an extra zero or two on the
 1 million figure and see if peoples machines cope with it then.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2385#comment:3>
