[postgis-tickets] [PostGIS] #2388: lwgeom_regress test fails on i386
PostGIS trac at osgeo.org
Fri Jul 19 01:42:54 PDT 2013
 Reporter:  mwanner                |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.4
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:                         |
 Any build of postgis-2.0.3 or source:/branches/2.0 at 11591 on i386 (and
 within a chroot) fails 'make check' for me.
 2.0.3 only fails on lwgeom_regress, r11591 shows the additional 'tickets'
 failure. None of these show up on 64bit builds (i.e. amd64).
 Everything below is from a build of r11591: ./configure says:
   PostGIS is now configured for i486-pc-linux-gnu
  -------------- Compiler Info -------------
   C compiler:           i486-linux-gnu-gcc -g -O2 -fstack-protector
 --param=ssp-buffer-size=4 -Wformat -Werror=format-security
   C++ compiler:         i486-linux-gnu-g++ -g -O2 -fstack-protector
   SQL preprocessor:     /usr/bin/cpp -traditional-cpp -P
  -------------- Dependencies --------------
   GEOS config:          /usr/bin/geos-config
   GEOS version:         3.3.3
   GDAL config:          /usr/bin/gdal-config
   GDAL version:         1.9.0
   PostgreSQL config:    /usr/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.1.9
   PROJ4 version:        47
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.1
   JSON-C support:       yes
   PostGIS debug level:  0
   Perl:                 /usr/bin/perl
  --------------- Extensions ---------------
   PostGIS Raster:       enabled
   PostGIS Topology:     enabled
  -------- Documentation Generation --------
   xsltproc:             /usr/bin/xsltproc
   xsl style sheets:     /usr/share/xml/docbook/stylesheet/nwalsh
   dblatex:              /usr/bin/dblatex
   convert:              /usr/bin/convert
   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
 Failing tests:
 lwgeom_regress .. failed (diff expected obtained:
 /tmp/pgis_reg/test_27_diff)
 tickets .. failed (diff expected obtained: /tmp/pgis_reg/test_66_diff)
 $ cat /tmp/pgis_reg/test_27_diff
 --- lwgeom_regress_expected     2013-04-10 15:34:25.000000000 +0000
 +++ /tmp/pgis_reg/test_27_out   2013-07-19 07:48:22.998406489 +0000
 @@ -1,5 +1,5 @@
  BOX(0 0.1,11 12)
 -BOX3D(0 0.1 -55,11 12 12)
 +BOX3D(0 0.1 -55,11 12 4.75497462555748e+104)
  11184
  15824
  20464
 $ cat /tmp/pgis_reg/test_66_diff
 --- tickets_expected    2013-07-19 07:16:53.000000000 +0000
 +++ /tmp/pgis_reg/test_66_out   2013-07-19 07:48:32.998407050 +0000
 @@ -233,4 +233,4 @@
  #2110.1|f
  #2110.2|t
  #2110.3|t
 -#2307|MULTIPOLYGON(((-41.1932 -7.3257,-41.1616 -7.3257,-41.1569
 -7.3257,-41.1569 -7.3483,-41.1932 -7.3483,-41.1932 -7.3257),(-41.1616
 -7.3257,-41.1879 -7.3257,-41.1879 -7.3425,-41.1616 -7.3425,-41.1616
 -7.3257)))
 +#2307|MULTIPOLYGON(((-41.1932 -7.3257,-41.1616 -7.3257,-41.1569
 -7.3257),(5.78163017139907e+194 4.36414105401949e+254,27883.4492
 -4.2942574203874e+301,6.46654932641944e+118
 7.54575043065372e+107,9.90794679509237e+117 6.46734808040511e+118,-41.1616
 -7.3257)))
 Also note that I initially suspected my own patches for Debian to cause
 this. However, all of the above applies to the unpatched release or svn
 checkout as well.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2388>
