[postgis-tickets] [PostGIS] #2388: lwgeom_regress test fails on i386
PostGIS trac at osgeo.org
Fri Jul 19 04:31:01 PDT 2013
 Reporter:  mwanner                |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.4
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:                         |
Comment(by robe):
 FWIW: The first error is one I've seen before  under our windows
 mingw64-w32 build bot a while ago.  For the BOX3D case I ended up just
 changing the offending test as described in #2020 (though your failure
 might be different reason).   Because I thought it was an unfair test and
 the last coordinate is not predictable from the code.
 Your second error test_66_diff I suspect your regress is hooking up with
 an ancient lwgeom.so you have installed in system.  The reason I say that
 , is the second test is a fairly new test put in to test that particular
 issue, so if you were running an out of date lwgeom, you'd fail that test.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2388#comment:1>
