[postgis-tickets] [PostGIS] #2391: TopoGeo_AddPolygon splits again on second call
PostGIS trac at osgeo.org
Fri Jul 26 10:16:59 PDT 2013
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.2.0
Component:  topology  |     Version:  2.1.x
 Keywords:            |
Comment(by robe):
 I didn't read through all the #2175, but I've concluded this isn't really
 a bug since I end up with the same face in both cases.  The only
 difference is when you run the second time, the first edge is split at (
 -123.39807825809805 48.41413244074219 )
 and ( -123.38462716264604 48.44945686262085 )
 and In the second its just a single line string.  If you take the set of
 points that forms both, (I tested with ST_AsText EXCEPT), you end up with
 the same set of points as well.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2391#comment:3>
