[postgis-tickets] [PostGIS] #2391: TopoGeo_AddPolygon splits again on second call
PostGIS trac at osgeo.org
Fri Jul 26 10:18:49 PDT 2013
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.2.0
Component:  topology  |     Version:  2.1.x
 Keywords:            |
Comment(by robe):
 Then again, I'm still bothered why running a process twice results in
 different keys. Only reason I am bothered by this is that it means you
 can't easily use this function to populate a table since the second time
 you run it, the edge ids will be different.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2391#comment:4>
