[postgis-tickets] [PostGIS] #2223: Rules on geometry_columns make noisy backup/restore
PostGIS trac at osgeo.org
Thu Jun 6 20:49:14 PDT 2013
 Reporter:  pramsey                |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.4
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:  rules                  |
Comment(by rburhum):
 There are actually two cases:
 1.- {{{ pg_dump -FC }}}  && {{{ pg_restore }}}
 2.- {{{ pg_dump }}} (default) && {{{ psql -f }}}
 Versions of source and destination server:
 In the server (where the pg_dump is generated):
 project_5=# select postgis_version();
             postgis_version
  2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
 /usr/lib/postgresql/9.1/bin/psql --version
 psql (PostgreSQL) 9.1.9
 contains support for command-line editing
 In the local machine (where the pg_restore is called)
             postgis_version
 (1 row)
 psql --version
 psql (PostgreSQL) 9.2.4
 So it looks like they are the same postgis, but different postgresql.
 For the second case With {{{ pg_dump -FC }}} (the custom postgres format)
 I don't even get the full postgis tables/views back.
 I just switched to using the (default) text-based pg_dump and and pipe to
 psql for the restore (the 1st case). In that scenario, I get the
 tables/views back but the permissions are not maintained.
 If understood you right, it seems that you may have the 2nd case fixed,
 but perhaps the first one is not?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2223#comment:9>
