[postgis-tickets] [PostGIS] #2351: Postgis 2.1 st_distance between geographies wrong
PostGIS trac at osgeo.org
Thu Jun 6 22:55:29 PDT 2013
 Reporter:  mamay    |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 Results between the below queries are very different (but assumed to be
 identical, or very closed):
 1) SELECT st_distance('SRID=4283;LINESTRING(149.386990599235
 -26.3567415843982,149.386990599247 -26.3567415843965,149.387026257283
 -26.3567362980298,149.387125078815 -26.3567216575441,149.387223900317
 -26.3567070169918,149.387322721788 -26.356692376373,149.387421625802
 -26.3566777343106,149.387520447213 -26.3566630935584,149.387619268592
 -26.3566484527397,149.387718089941 -26.3566338118544,149.38781691126
 -26.3566191709025,149.387915732548 -26.3566045298841,149.388014553806
 -26.356589888799,149.388113375033 -26.3565752476473,149.38821219623
 -26.356560606429,149.388311017396 -26.3565459651442,149.388409838532
 -26.3565313237927,149.38850874221 -26.3565166809971,149.388607563285
 -26.3565020395124,149.388706384329 -26.3564873979611,149.388720054423
 -26.3564853653255,149.388755888538 -26.3564806169646,149.388805686816
 -26.3564760867424,149.388855694739 -26.3564737184747,149.388905749016
 -26.3564736051138,149.388955768932 -26.3564758382342,149.388991180786
 -26.3564786760044,149.389005666353 -26.3564801486226,149.389105155017
 -26.3564899474185,149.389204726265 -26.3564997447661,149.389304295669
 -26.3565094518463,149.389403866939 -26.356519249053,149.38950343822
 -26.3565290461892,149.389603009512 -26.3565388432549,149.389702580815
 -26.3565486402502,149.389802152129 -26.356558437175,149.389901723455
 -26.3565682340293,149.390001294791 -26.3565780308132,149.390100864283
 -26.3565877373297,149.390200435641 -26.3565975339727,149.390300007011
 -26.3566073305452,149.390399578391 -26.3566171270472,149.390499149782
 -26.3566269234787,149.390598721185 -26.3566367198398,149.390698210025
 -26.3566465175092,149.39079778145 -26.3566563137294,149.390897352885
 -26.3566661098792,149.390996922476 -26.3566758157616,149.391096493934
 -26.3566856117704,149.391138458852
 -26.3566897832034)'::geometry::geography,
 'SRID=4283;POINT(149.386990599235
 -26.3567415843982)'::geometry::geography);
 -- results 15630629.1006441 meters!
 2) SELECT st_distance(st_transform('SRID=4283;LINESTRING(149.386990599235
 -26.3566856117704,149.391138458852 -26.3566897832034)'::geometry, 999155),
 st_transform('SRID=4283;POINT(149.386990599235
 -26.3567415843982)'::geometry, 999155));
 -- result 0, which is correct.
 POSTGIS="2.1.0beta3dev r11503" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6
 March 2012" GDAL="GDAL 1.10dev, released 2011/12/29" LIBXML="2.7.3"
 LIBJSON="UNKNOWN" RASTER
 OSX 10.7.5
 same result on ubuntu 11.10 postgis 2.1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2351>
