[postgis-tickets] [PostGIS] #2358: Add post-check phase to PostGIS build
trac at osgeo.org
Sat Jun 8 14:02:00 PDT 2013
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.2.0
Component: build/upgrade/install | Version: 2.0.x
Keywords: |
Right now we are probalby the only extension that does our check before
install. This is great because it allows you to do a quick check before
you screw up your postgresql system, but is bad because there is no way to
install actually works and will install all the necessary plumbing. It
also means we have no way of verifying CREATE EXTENSION or even doing a
true check of upgrade.
I propose a post-check option to solve this that is a check done after
install. Since it is done after install it has a couple of benefits
1. It can be run with CREATE EXTENSION thus testing our extension building
2. We can easily squeeze in a true upgrade test in here since our model
allows for installing multiple versions of postgis in the same instance.
So a switch something like --with-upgrade-from=2.0.4SVN
Will in post-check phase do a:
CREATE EXTENSION postgis VERSION "2.0.4SVN";
ALTER EXTENSION postgis UPDATE TO "2.1.0";
Since both winnie and debbie are doing make installs (have to double-check
on debbie, but winnie definitely is), they'll be able to take advantage of
this new flag to do a true upgrade regression test.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2358>
