[postgis-tickets] [PostGIS] #2358: Add post-check phase to PostGIS build
PostGIS trac at osgeo.org
Sat Jun 8 14:10:06 PDT 2013
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  high                   |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:                         |
Description changed by robe:
Old description:
> Right now we are probalby the only extension that does our check before
> install.  This is great because it allows you to do a quick check before
> you screw up your postgresql system, but is bad because there is no way
> to install actually works and will install all the necessary plumbing.
> It also means we have no way of verifying CREATE EXTENSION or even doing
> a true check of upgrade.
> I propose a post-check option to solve this that is a check done after
> install.  Since it is done after install it has a couple of benefits
> 1. It can be run with CREATE EXTENSION thus testing our extension
> building
> 2. We can easily squeeze in a true upgrade test in here since our model
> allows for installing multiple versions of postgis in the same instance.
> So a switch something like --with-upgrade-from=2.0.4SVN
> Will in post-check phase do a:
> CREATE EXTENSION postgis VERSION "2.0.4SVN";
> ALTER EXTENSION postgis UPDATE TO "2.1.0";
> Since both winnie and debbie are doing make installs (have to double-
> check on debbie, but winnie definitely is), they'll be able to take
> advantage of this new flag to do a true upgrade regression test.
New description:
 verify the install actually works and will install all the necessary
 plumbing.  It also means we have no way of verifying CREATE EXTENSION or
 even doing a true check of upgrade.
 1. It can be run with CREATE EXTENSION thus testing our extension building
 Since both winnie and debbie are doing make installs (have to double-check
 on debbie, but winnie definitely is), they'll be able to take advantage of
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2358#comment:1>
