[postgis-tickets] [PostGIS] #2185: Geometry output functions crash server with invalid WKT
PostGIS trac at osgeo.org
Tue Jun 18 21:12:55 PDT 2013
  Reporter:  mwtoews  |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.0.4
 Component:  postgis  |     Version:  2.0.x
Resolution:  fixed    |    Keywords:  windows 64
Comment(by robe):
 Yap works fine with 4.8 testing against EDB 9.3 beta 1 x64-bit on my
 Windows 7 64-bit if I back out my changes.  Though have to leave these in
 since I'll still be using 4.5.4 for 9.2/9.1 (9.0 PostgreSQL as noted here
 http://www.postgresql.org/message-id/14242.1365200084@sss.pgh.pa.us ) I
 don't even think supports compiling with gcc 4.8.0 then again I'm not sure
 any windows users use 64-bit 9.0 and if they do if 9.0 even has the issue
 seems to be more of an issue with VS 2010 than VS 2008 I think perhaps
 because VS 2008 is closer in family to 4.5.4.  That might also be why for
 9.1 I've only seen the issue under windows 2008/windows 7.0 64-bit (not my
 windows 2003 64-bit) since the newer windows OS are more likely to have
 external dependencies built with newer VS 2010 that PostgreSQL relies on
 (even when running a 9.1 built with VS 2008).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2185#comment:49>
