[postgis-tickets] [PostGIS] #2365: find_srid performance regression with large numbers of tables
PostGIS trac at osgeo.org
Wed Jun 19 09:42:24 PDT 2013
 Reporter:  angrygoat  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  low        |   Milestone:  PostGIS 2.1.0
Component:  postgis    |     Version:  2.0.x
 Keywords:             |
 The speed of find_srid has dropped significantly in PostGIS >= 2.0 when a
 large number of tables exist in the database. It looks like this is
 related to the new definition of geometry_columns as a view.
 On my system, for a database containing a hundred tables find_srid() takes
 ~ 10ms, with five thousand tables ~ 100ms, with fifteen thousand tables ~
 450ms.
 I'm not sure if this is a bug or a regression you'd consider worth fixing,
 however mapserver's postgis vector data source will put a find_srid() call
 in every query if the user doesn't specify "using srid=<srid>". With
 PostGIS>=2.0 on a database with lots of tables, not specifying the srid is
 suddenly a massive (rather than very minor) performance issue.
 I've attached a rather ugly shell script that reproduces the issue :-)
 Thanks!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2365>
