[postgis-tickets] [PostGIS] #2213: postgis-2.1.so: undefined symbol: json_tokener_errors
PostGIS trac at osgeo.org
Fri Jun 21 06:14:32 PDT 2013
  Reporter:  mloskot  |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.1.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:  json-c
Comment(by robe):
 I build json as a static library instead of shared.  In 0.9 it naturally
 does that for under mingw, in 0.10 I build with --disable-shared --enable-
 static.  Anyrate I think its dangerous to assume people have only one
 version of libjson on their system especially for package maintainers
 where they DON'T necessarily want the one installed in default system
 folder used.  That's what I thought the point is of having the   --with-
 jsondir option.
 If we can't fix this this change has to be backed out of 2.1.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2213#comment:28>
