[postgis-tickets] [PostGIS] #2213: postgis-2.1.so: undefined symbol: json_tokener_errors
trac at osgeo.org
Fri Jun 21 06:54:21 PDT 2013
Reporter: mloskot | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Resolution: | Keywords: json-c
Comment(by strk):
Robe, so do you have a custom libjson-0.9 in the dir specified using
--with-jsondir and a libjson-0.10+ in a standard library dir ?
The code isn't actually assuming you have one, but for some reason it's
failing to use -L, are you sure you did use a --with-jsondir option ? The
patch doesn't drop that.
Could you paste the full ./configure invocation and the output lines
matching "json" ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2213#comment:29>
