[postgis-tickets] [PostGIS] #2369: SQL Statemant Works in Windows version 1.5x Not in Liunx version 2.0x
PostGIS trac at osgeo.org
Tue Jun 25 13:01:20 PDT 2013
 Reporter:  vbalent  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by dustymugs):
 Have you checked the output of ST_AsEWKT(geom)? Just because the SRID is
 2260, doesn't mean the coordinates are.
 According to spatialreference.org, coordinates for 2260 should be bounded
 between 116071.8523, 747947.1638, 837761.3518, 2260847.6417. If your
 coordinates aren't in those bounds, you have a mismatch between what the
 coordinates truly are and what projection someone says they are.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2369#comment:4>
