[postgis-tickets] [PostGIS] #2369: SQL Statemant Works in Windows version 1.5x Not in Liunx version 2.0x
PostGIS trac at osgeo.org
Tue Jun 25 17:05:18 PDT 2013
  Reporter:  vbalent  |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 2.0.4
 Component:  postgis  |     Version:  2.0.x
Resolution:  invalid  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 vbalent based on the last ticket you  posted, I suggested you do the below
 query because given the convoluted query you gave I had already concluded
 your data is stamped as 2260 but is really in wgs 84 long lat (4326) as
 Bborie also mentioned above.
 Sorry I had a typo in the last ticket could I gave.  I apologize for the
 confusion there.  You should run this
 ALTER TABLE part_1_crimes ALTER TYPE geom geometry(POINT,2260) USING
 ST_Transform(ST_SetSRID(geom, 4326),2260);
 I'm marking this as invalid again because your issue seems to not be a bug
 but just a newbie misunderstanding about using PostGIS.  Please  subscribe
 to our user's list and post your questions there before assuming they are
 bugs in the software.
  http://lists.osgeo.org/mailman/listinfo/postgis-users
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2369#comment:5>
