[postgis-tickets] [PostGIS] #2369: SQL Statemant Works in Windows version 1.5x Not in Liunx version 2.0x
PostGIS trac at osgeo.org
Tue Jun 25 17:08:33 PDT 2013
  Reporter:  vbalent  |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 2.0.4
 Component:  postgis  |     Version:  2.0.x
Resolution:  invalid  |    Keywords:
Comment(by robe):
 hmm I should probably try running code before I post it.  here is yet
 another typo correction.
 ALTER TABLE part_1_crimes
  ALTER COLUMN geom TYPE geometry(POINT,2260)
     USING ST_Transform(ST_SetSRID(geom, 4326),2260);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2369#comment:6>
