[postgis-tickets] [PostGIS] #2369: SQL Statemant Works in Windows version 1.5x Not in Liunx version 2.0x
PostGIS trac at osgeo.org
Wed Jun 26 06:22:21 PDT 2013
  Reporter:  vbalent  |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 2.0.4
 Component:  postgis  |     Version:  2.0.x
Resolution:  invalid  |    Keywords:
Comment(by vbalent):
 Yes I checked the 2 different tables I am using.
 I used the Function ST_AsEWKT(geom)
 My polygon Table is SRID 2260 with True Us East State Plane Coordinates
 My points table is SRID 2260 with Lat Long Values.
 I will run the command you sent so that they are both in the Same Geometry
 not just said SRID.
 I hope this command works and not break anything on my other apps.
 I understand they should all be in the same geometry everything.
 My point and why I said it might be a defect is that It worked in Windows
 64 bit,
 but now it did not work in Linux 64 bit.
 Thanks,
 Val
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2369#comment:7>
