[postgis-tickets] [PostGIS] #2230: pgsql2shp fails with named schema on windows 64
PostGIS trac at osgeo.org
Tue Mar 12 16:09:11 PDT 2013
 Reporter:  robe       |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  critical   |   Milestone:  PostGIS 2.0.4
Component:  postgis    |     Version:  2.0.x
 Keywords:  windows64  |
 This is a note from Jeff:
 http://lists.osgeo.org/pipermail/postgis-devel/2013-March/023297.html
 I just tested and confirmed its the same issue with 2.0.3. I think we had
 a similar issue a while back with shp2pgsql and perhaps because that is
 more heavily tested it was caught there.
 pgsql2shp -f "c:/test.shp" -g geom -u "postgres" -h t -p 5432 -P
 "mypassword" mygisdb public.constrained_geoms
 The is is the . is being put in the wrong spot this is what the log shows:
 SELECT a.attname, a.atttypid, a.atttypmod, a.attlen FROM pg_attribute a,
 pg_class c, pg_namespace n WHERE n.nspname = 'public.' AND a.attrelid =
 c.oid AND n.oid = c.relnamespace AND a.atttypid != 0 AND a.attnum > 0 AND
 c.relname = 'constrained_geoms'
 note the public. instead of public
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2230>
