[postgis-tickets] [PostGIS] #2239: regress failure on postgresql 9.0 on windows
PostGIS trac at osgeo.org
Fri Mar 22 08:59:04 PDT 2013
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:  windows  |
Comment(by robe):
 No. You can take it out.  I think the issue is that the
 postgis.sql.in is being overwritten each call.
 So the cpp stuff is working fine, since if I switch order of regress, 9.0
 passes and the others fail.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2239#comment:12>
