[postgis-tickets] [PostGIS] #2239: regress failure on postgresql 9.0 on windows
PostGIS trac at osgeo.org
Fri Mar 22 09:10:25 PDT 2013
  Reporter:  robe     |       Owner:  strk
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.1.0
 Component:  postgis  |     Version:  trunk
Resolution:  invalid  |    Keywords:  windows
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Nevermind.  I'm pretty sure it was because for some reason the svn update
 did not delete the old postgis.sql.in and so didn't pull the new one.
 I'll double-check the svn pull logic.  It may be different from what I
 have on debbie.  Deleting the file which forces the pull I think fixed the
 issue, so you can take out that -x c
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2239#comment:13>
