[postgis-tickets] [PostGIS] #1580: proj4 cache corrupted by projection error ?
PostGIS trac at osgeo.org
Mon Sep 16 08:39:49 PDT 2013
  Reporter:  strk      |       Owner:  pramsey
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.0.0
 Component:  postgis   |     Version:  trunk
Resolution:  fixed     |    Keywords:
Changes (by caleb):
 * cc: caleb (added)
Comment:
 I believe I'm having this same issue. First I get an error like:
 SELECT SUM(count*ST_X(cluster_point))/SUM(count) as center_x,
  SUM(count*ST_Y(cluster_point))/SUM(count) as center_y,
  SUM(count) as count FROM "clusters" WHERE (zoom = 9 AND
 ST_INTERSECTS(polygon,ST_TRANSFORM(ST_SETSRID(ST_MakeBox2D(ST_POINT(26.816068571769904,89.99999737698666),
  ST_POINT(29.507718962394904,89.9999974989205)),4326),900913))) GROUP BY
 grid_point
 PG::Error: ERROR:  transform: couldn't project point (26.8161 90 0):
 tolerance condition error (-20)
 Then, all following transformations throw an error like:
 PG::Error: ERROR: AddToPROJ4SRSCache: couldn't parse proj4 string:
 '+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
 +units=m +k=1.0 +nadgrids=@null +no_defs': tolerance condition error
 Only solution seems to be to restart the PostgreSQL server.
 This is occurring with PostGIS 1.5. Assuming this is the same, and the
 above fix is the resolution: which stable version did this fix made it
 into?
 Thanks!
 Caleb
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1580#comment:3>
