[postgis-tickets] [PostGIS] #1580: proj4 cache corrupted by projection error ?
PostGIS trac at osgeo.org
Mon Sep 16 15:20:12 PDT 2013
  Reporter:  strk      |       Owner:  pramsey
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.0.0
 Component:  postgis   |     Version:  trunk
Resolution:  fixed     |    Keywords:
Comment(by robe):
 this sounds like it got fixed in PostGIS 2.0.0 and did not get backported.
 Can you provide the
 SELECT version() || ' ' || postgis_full_version();
 you are using. My guess is this isn't going to be hard to backport, but we
 didn't because the audience for 1.5 is diminishing significantly so if you
 get from a package maintainer you might have a ways to wait.  If you
 compile yourself and its causing you serious problems we can probably
 patch in short order.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1580#comment:4>
